With which settings can i print FormFutura Styx 12 (Nylon), which temperature? Does not stick on bed
3DPrint - YS
(@3dprint-ys)
Hi folks
I just got recently a Prusa MK3 and now i want to print FormFutura Nylon Styx 12, but it does not stick to the bed.
In Prusa Slicer, i've choose the Taulman Brigde because i think its the most similar preset.
For the First Layer, it recommends a bed temperature as 60° and a extruder temp 240°, and then in the second layer 90° / 250° 😳
So i have 2 Problems: First, how shall the filament stick to the bed? Which temperature? Theres also no clear preheat setting for PA, i tried it with ABS for the filament change... and how will the bed get 30° more in just that short period of time?
Do you have some experience with this issue?
Thanks
Opublikowany : 14/09/2019 9:03 am
Peter M
(@peter-m)
RE: With which settings can i print FormFutura Styx 12 (Nylon), which temperature? Does not stick on bed
Here are the print settings,
https://www.formfutura.com/shop/product/styx-12-clear-972
1 layer hotter, then it sticks better,
adjust height of first layer, this needs to be perfect,
use glue stick .
Opublikowany : 15/09/2019 7:38 am
3DPrint - YS
(@3dprint-ys)
Thanks, but now I think I screwed it up completely.
Now the printer is broken, and prusa hasnt not a proper preset for that.
I have now thermal runaway error.
I could come from the fan speed but i didnt change anything but for Nylon it was supposed to do 🙁
Opublikowany : 15/09/2019 9:18 am
