[Risolto] Wierd slicing of model
Japanese green tea
(@japanese-green-tea)
Hello. Could you please help me? Why the shown model in video is sliced in this way? I have tried made some set up, but nothing helped... or is caused by model format STL? o.
Postato : 12/10/2020 7:25 am
Baklin
(@baklin)
RE: Wierd slicing of model
Looks like you haven't placed the part on a flat side in the slicer.
Have a look at this page of the manual.
https://help.prusa3d.com/en/article/place-on-face-tool_1781
Postato : 12/10/2020 8:37 am
2 persone hanno apprezzato
Japanese green tea
@baklin
Thanks a lot man... It worked!
Postato : 12/10/2020 6:13 pm
jsw
 jsw
(@jsw)
I had a similar issue with a piece that was drafted at an angle.  When I imported it into PS and manually set the angle to compensate, it was not perfectly aligned with the print bed and refused to properly slice.  One of the others here tried it and said it worked and it turned out that he was using the place-on-face function, which I now use instead of an inputted angle.
I was used to Cura's 'snap to' function which automatically places an almost-parallel surface parallel to the build plate.
Postato : 13/10/2020 1:53 am
