why is that?
Hello,
I am fully satisfied with my MK3s as an enthusiastic newcomer,
but I do not know what leads to this error in this print.
https://www.thingiverse.com/thing:1790624
The Detail is from the hinges:
It looks like spaghetti :-)
Thanks for your help
Greetings
Stefan
Opublikowany : 01/05/2019 2:59 pm
Topic starter
answered:
RE: why is that?
I've forgotten:
I have used Slic3er Prusa Edition 1.41.3 with Setup 0.15mm QUALITY MK3.
All options are on default values.
Opublikowany : 01/05/2019 3:27 pm
RE: why is that?
It appears to be a bridging issue; have you tried DETECT BRIDGING?
Opublikowany : 03/05/2019 6:50 am
RE: why is that?
Unrelated butif that is your first layer facing us in the photo, your live z value is not nearly negative enough.
Opublikowany : 03/05/2019 12:03 pm
RE: why is that?
Print settings -> Layers and perimeters -> Detect bridging perimeters seems needed for this print, however when I'm looking at it in a slicer, the horizontal joints are floating in the air, so they'll always be a bit tricky to print
Opublikowany : 03/05/2019 12:43 pm
