Why I have this phenomenon?
Claudio Gallo
(@claudio-gallo)
I want to know how can I resolve this problem?? I must say that the layer that I printing is 0,6 mm! I don't know if it is useful to know.
Thanks for attention
Claudio
Best Answer by JoanTabb:
Hi Claudio,
what size nozzle are you using?
typically the maximum reliable layer height is recommended to be no more than 80% of your nozzle diameter.
this means 0.32mm for a 0.4mm nozzle
a 0.8mm nozzlle |(with the correct slicer settings) should be able to print a 0.6mm layer height, reliably
Veröffentlicht : 13/06/2019 11:57 am
RE: Why I have this phenomenon?
Hi Claudio,
Veröffentlicht : 13/06/2019 12:32 pm
Claudio Gallo
(@claudio-gallo)
Good, is exact! Infact I have seen that the nozzle was touching the filament and it damages the print!
Thank you so much
Veröffentlicht : 13/06/2019 12:38 pm
Curious that at the edges the plastic is sticking, but not in the interior of the part.  Perimeters and infill at the edges are printed the slowest (infill acceleration hasn't kicked in).  So what ever is going on is also speed related.  Also looks to have overextrusion or z-helght too low?
Diese r Beitrag wurde geändert Vor 7 years von --
Veröffentlicht : 13/06/2019 3:51 pm
Linear advance issue?...   perhaps?
However if they are trying to print 0.6mn layer height with a 0.4mm nozzle. It's amazing that anything is sticking
Veröffentlicht : 13/06/2019 11:42 pm
My logic went like this: Brim looks okay, pretty normal really; I can't see layer 1 under the top layers of thicker stuff.   I understood the part to be 0.6 mm thick, not a single layer of 0.6 mm.  Good catch Joan.
Veröffentlicht : 13/06/2019 11:49 pm
