white spots
Nino Nobile
(@nino-nobile)
Utenti
white spots
Hello friends,
I've been printing a few cabinets and every now and then, even though I clean the base with soap and water, I run into these kinds of white spots. Someone else happens? Any advice to fix it?
Best regards!
Postato : 24/07/2020 10:59 pm
jsw
 jsw
(@jsw)
RE: white spots
It looks like glue residue to me.  I see it occasionally.  I assume this is the face that contacts the build plate.  It appears to be something on the plate that is causing it.
Postato : 24/07/2020 11:17 pm
Nino Nobile
(@nino-nobile)
Utenti
RE: white spots
@jsw
I don't think that's it, in fact I even cleaned the base before printing.
Postato : 25/07/2020 1:28 am
RE: white spots
Does the white stuff wash away or is it in the print?
Postato : 25/07/2020 1:41 am
Peter M
(@peter-m)
RE: white spots
Wash bed with dish soap a few times, and  use nothing else, then print again, is it gone?
Could be if you switch filament it leaves something behind, or only alcohol it does not clean all.(this is how alcohol cleans).
Also it could be something in the filament, test a different brand.
Postato : 25/07/2020 4:49 am
Nino Nobile
(@nino-nobile)
Utenti
RE: white spots
I'm going to try the tips that are happening to me and then I leave you a photo, I think I should wash with detergent and water after each impression, it may be because of the filament.
Postato : 25/07/2020 3:31 pm
