What's wrong with my model?
avuong34
(@avuong34)
I recently created a skull mask and uploaded it onto prusaslicer. But two problems came up.
First, there was a weird anomaly stretching across the nose. I double checked my blender model and other 3d modeling programs and it doesn't appear there. So I'm not sure what's going on with that.
Secondly, it appears to have been corrupted in which I had run it through netfabb to fix it. Not sure why it happened. But the nose thing is still there.
Is there something I am missing?
Best Answer by --:
Many different errors in the model ... that is what NetFabb is for.
Marias Mask (repaired)
Napsal : 01/11/2019 6:29 pm
rmm200
(@rmm200)
RE: What's wrong with my model?
Zip up your 3MF file and post it here.
That is needed for anyone to look at it.
Napsal : 01/11/2019 6:44 pm
Yep - without the part to examine - I can guess that the nose is not a Roman nose, therefore the printer refuses to print it.
ZIP the STL or OBJ file, post it;  or zip the exported project from P.Slicer (3MF format), post it.   Otherwise folk can make lots of guesses and be of no help to you whatsoever
This post was modified před 7 years 2 times by --
Napsal : 01/11/2019 7:20 pm
avuong34
(@avuong34)
maria's mask(4)
The dimensions I want it to be are x = 152.4, y = 69.8, and z = 177.8
The nose space should be empty. But just some random piece seems to stretch across it.
Napsal : 02/11/2019 1:58 am
Napsal : 02/11/2019 6:59 am
avuong34
(@avuong34)
Posted by: @tim-m30
Thanks a bunch.
what netfabb software did you use to fix it? I never really used them before as I used makerbot before prusa as no issues appeared before. So I'm going to start running my projects through it now.
Napsal : 02/11/2019 2:02 pm
