whats gone wrong now 🙁
widget2k13
(@widget2k13)
ive had quite a few good prints but having a huge issue trying to get a first layer down now, sometimes it works no problem other times it takes dozens of attempts for it to work, i have done loads of z tuning over and over and always are perfect but its starting to really become a pain now, i have cleaned the bed with hot water and dish soap, scrubbed it, cleaned it with alcohol, it doesn't seem to be a bed adhesion problem as the bits that are stuck are really good, it seems to be when shifting it either leaves a blob or doesn't print small parts of the print, i dont know if i have changed a setting that i dont recall or not but i have tried changing about everything with no difference, once the first layer is down it prints perfectly, i have tried several pla, and pteg and its always the same results either works first time or takes loads of attempts, no set outcome its like a lucky dip, added a photo to give an example of what happens.
Veröffentlicht : 21/02/2020 11:29 pm
vintagepc
(@vintagepc)
Mitglied
RE: whats gone wrong now 🙁
What brand filament are you using, and/or are you handling it with bare hands? Filament contamination can cause problems that look just like a bad live Z or dirty bed...
https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/psa-do-not-overlook-your-filament-as-a-source-of-adhesion-issues/
Veröffentlicht : 22/02/2020 12:32 am
widget2k13
(@widget2k13)
@vintagepc
I’ve tried prusament and general pla all brand new rolls not been touched by hand , I’ve cleaned the bed over and over , done my live z over and over and it’s perfect , just one time it prints perfect then it prints like that loads of times
Veröffentlicht : 22/02/2020 8:48 am
widget2k13
(@widget2k13)
here is attached image of my live z result without touching it during the print, this is the best i can get it
Veröffentlicht : 22/02/2020 9:31 am
Lichtjaeger
(@lichtjaeger)
Posted by: @keithcowell
To low. Raise the nozzle a bit.
Veröffentlicht : 22/02/2020 10:13 am
widget2k13
(@widget2k13)
@lichtjaeger
If I raise the nozzle even a little bit this happens
Veröffentlicht : 22/02/2020 10:16 am
Lichtjaeger
(@lichtjaeger)
@lichtjaeger
This is even lower, not higher. Change in + direction (lesser value) not -.
Veröffentlicht : 22/02/2020 10:19 am
widget2k13
(@widget2k13)
@lichtjaeger
That is higher , it was -1.500 then I changed it to -1.450 then it pulls filament off the plate
Veröffentlicht : 22/02/2020 10:37 am
Lichtjaeger
(@lichtjaeger)
That is a very big value. 😲
You should consider readjusting the PINDA.
And you should clean your bed.
Veröffentlicht : 22/02/2020 10:43 am
widget2k13
(@widget2k13)
@lichtjaeger
If I try the pinda adjustment then the nozzle moves the paper on calibration :/ the bed has been cleaned and cleaned dozens of times , this is what’s happening on first layer cal now
Veröffentlicht : 22/02/2020 10:50 am
Lichtjaeger
(@lichtjaeger)
@lichtjaeger
This is XYZ calibration and should be done after PINDA adjustment. Please read the manual I linked.
Adjusting the PINDA could also solve your problem with XYZ calibration.
Veröffentlicht : 22/02/2020 10:56 am
widget2k13
(@widget2k13)
@lichtjaeger
I am starting again by the manual with zip tie etc , I don’t see your link ?
Veröffentlicht : 22/02/2020 11:11 am
widget2k13
(@widget2k13)
I started again set the pinda with the zip tie etc now my live z is at -1000 instead of -1450 but still results are bad , I’m going to have to give up on this for today
Veröffentlicht : 22/02/2020 11:18 am
widget2k13
(@widget2k13)
after being onto support for about 5 hours and trying everything we could think of the best ive got it to is this , they said it may need the thermal paste replaced in the heatbreak ? could that be the case with a 4 week old printer thats printed about 5 things ? or are they grasping at straws
Veröffentlicht : 22/02/2020 11:06 pm
