what is causing this stringing?
Astro Physicist Guy
(@astro-physicist-guy)
Miembro
I recently had my i3 Mark 3S serviced after 3,800 hrs of print time.  since then I'm getting this spider webbing, stringing on all my prints when it never happened before.  Don't know that the servicing necessarily caused this as I don't know if they tweaked any settings?  This happens using both PLA and PETG.  Thx!
Respondido : 11/03/2024 10:21 pm
Nimitz
(@nimitz)
RE: what is causing this stringing?
Any ideas?
Respondido : 15/03/2024 12:11 am
Dry your filament.  Reprint. Show us the result and if the issues remain save your project as a .3mf file
Files > Save Project as
Respondido : 15/03/2024 8:30 am
Astro Physicist Guy
Miembro
print was the first one of a brand new roll of hatchbox PLA that I just opened. attached is the .3mf file
mandible zip
Respondido : 15/03/2024 5:58 pm
Zappes
(@zappes)
So far, I only had two situations in which PLA caused stringing like this - one was with wet filament and one when I accidentally printed PLA with PETG settings, i.e. much too hot. Could it be that you somehow damaged the hotend thermistor or part cooling fan during your maintenance?
I would also push the filament spool through a drying cycle, even if it was brand new. Sometimes even new filament spools can be wet - the wet filament situation I mentioned was such a case.
My models on Printables
Respondido : 16/03/2024 11:28 am
Have you printed this part before?
There is nothing obviously wrong with your settings 'though I would use cubic fill and snug or organic supports and I see no advantage in 0.15 layers, you may as well use 0.2mm - and I would try support on the print-bed only...
But this part is not designed for 3D printing, all the lower curves will print poorly and I cannot find an orientation which will reduce the problem.  If you have access to the design files flatten the base and chamfer the edges instead of filletting.  Otherwise 'cut' the part into quarters, print and assemble post-printing.
I repeat, dry your filament.
Respondido : 16/03/2024 5:03 pm
