What is causing these globs at my corners, what slicer settings do i need to adjust?
0.6mm nozzle
0.35mm speed
Prusament PETG recycled.
Este debate ha sido modificado el hace 3 years por J D
Respondido : 28/12/2022 4:32 am
RE: What is causing these globs at my corners, what slicer settings do i need to adjust?
Might be a cooling issue, or a leaking hot end. But as mentioned before: post a zipped prusa slicer project file, it contains all the data needed. Without that it's just guess work. A picture and two parameters are just not enough...
Respondido : 28/12/2022 12:22 pm
