What i am doing wrong?
matjazr
(@matjazr)
I was trying to print this nice figure: https://makerworld.com/en/models/1842460-daffy-duck-mall-pants-no-ams#profileId-1968540
So i grab out obj_15_ARM2.stl and try to slice it in prusa slicer...Put some supports, but printing does not work.
After printing just get bulb on printer....need some help, from scratch 😉
Opublikowany : 24/11/2025 10:15 am
Not well designed for 3D printing but it should be possible ... I would begin with snug supports rather than organic.
It's not stable: to reduce wobble rotate it 90° on the print sheet so the Y movements don't shake it so much.  Consider slowing the print.
Opublikowany : 24/11/2025 11:33 am
matjazr
(@matjazr)
RE: What i am doing wrong?
ok....will test....only 90° didn't get how u mean?
Opublikowany : 24/11/2025 11:41 am
In your picture the part is aligned across the print sheet so every movement of the bed shakes it sideways, turn it so that the major shaking is lengthways where it is more stable.
Opublikowany : 24/11/2025 11:52 am
