Weird Bumps with Gyroid Infill
tim.o14
(@tim-o14)
The attached photo shows volumetric flow rate for a PETG cube on standard settings at 0.2mm layer height. Doese anyone know why the flow rate fluctuates like this?
It produces noticable protrusions / larger dimensions at the corners of the cube, a little annoying.
Thanks!
Napsal : 10/01/2021 5:01 am
Swiss_Cheese
(@swiss_cheese)
RE: Weird Bumps with Gyroid Infill
If you zip up and post a .3mf project file we may be able to examine and tell you why, or explain how to change the outcome, every single model is different with 100's if not thousands of different slicing combinations based on selected preferences, we need to see what your doing to know.
The Filament Whisperer
Napsal : 10/01/2021 6:33 am
tim.o14
(@tim-o14)
Yeah I figured it out-- the cooling tab in filament settings, it looks like the time for some layers were just under the settings, and the other layers were above. Thanks!
Napsal : 10/01/2021 7:42 am
Swiss_Cheese
(@swiss_cheese)
I'm glad you were able to work it out.
Enjoy
Napsal : 10/01/2021 8:39 am
