Warping/bubbling on Top Surface for print that used to run fine
Platonicsolid
(@platonicsolid)
Good morning. I'm having a hell of a time getting a set of game tiles to print successfully on my MK3s+. What's doubly bedeviling is that I've printed these before with no issues - for some reason running them now gets me bad top surfaces, and I have other prints that are coming out just fine.
Here's the print with PrusaSlicer default 0.2 Quality settings. You can see the pillows/waves around the top and left of the print.
Hex at default 0.2 Quality
I did try a print with an increase to eight top layers, rather than the default six, and it seemed to improve things somewhat, but not completely. There's still a couple noticeable blisters in the lower left.
I'm rather at the end of my rope and would appreciate any advice. I'm wondering if I might have a wonky cooling fan? It definitely runs, but maybe it's slowed in some way over time, which would explain why this used to print fine and now doesn't?
Thanks!
Publié : 30/10/2022 3:06 pm
RandyM9
(@randym9)
RE: Warping/bubbling on Top Surface for print that used to run fine
Is the bottom of the finished print under the affected area perfectly flat? If you have even a slight amount of warping on that corner it will affect the top layers. Make sure your print sheet is clean.
Cheers
Publié : 31/10/2022 4:24 am
Platonicsolid
(@platonicsolid)
Did a few things to try to fix this.
  • Cleaned the print sheet.
  • Replaced the print fan. Seemed like it was making a grinding noise, this may have been a red herring
  • Recalibrated, nozzle is a little higher than it was before.
  • Tried a slightly lower print temperature.
  • Tried a different filament
  • Add a brim to keep the edges down.
I think the print fan didn't help, recalibrating and the lower print temperature did. I was able to get a good print out, and then ran another last night with two prints on the bed, and got this:
So maybe one area of the build plate is a bit more worn than the other? I'm trying a print now in that front left area to see if that makes a difference.
Publié : 10/11/2022 11:49 am
Platonicsolid
(@platonicsolid)
The plot thickens.
An additional print in the same location as the previous one that came out good shows notable waving.
So now I don't know what to think. Maybe a bad thermistor?
Here's what Octoprint tracked for the last part of the print - all the graph I have.
So it certainly seems to be keeping a stable temperature, but that presumes the thermistor is reporting accurately.
Publié : 10/11/2022 3:03 pm
RandyM9
(@randym9)
Just double checking - you’re sure there’s no warping of the part as it prints?
Have you dried your filament?
What material are you printing?
Have you printed a temperature tower to see where the potential best setting lies?
Cheers
Publié : 10/11/2022 7:54 pm
