Variable Print speed in each layer - 1mm nozzle
I am having gapping issues at the start of each layer with a 1mm nozzle. I have tried many things to improve this with nozzle temp, detraction length, etc, but here we are. This isn't my picture but it's the same thing.
Is there a way to set a variable speed per layer so that it starts off slow (~15mm/s), then speeds up (40mm/s) after a certain percentage of the layer, or distance?
Example:
Opublikowany : 10/01/2024 2:59 am
