Updated to latest firmware and this started
Peter Shell
(@peter-shell)
Any help would be much appreciated. This is Nylon Carbon X being printed at 265*. I've had many successful prints with this material until now.
Thanks!
Postato : 01/08/2018 3:30 pm
Re: Updated to latest firmware and this started
Hi Peter,
that looks like under extrusion.
can you check the bond tech idler pin is still in place, people report this coming dislodged at one end.
similarly it could be a partially blocked nozzle
could the filament have got damp?
(although why it should do this at exactly the same time that you changed firmawre,)
if this is ok, try reflashing, the old firmware.
regards
Postato : 01/08/2018 4:34 pm
