Underextrusion issues immediately after firmware update
[Solved] Underextrusion issues immediately after firmware update
turtlelore2
(@turtlelore2)
So I finally updated the firmware last night and finished an overnight print, but right afterwards I suddenly get tons of underextrusion. I also just fixed an extruder clicking problem at the same time by readjusting the idler screw. I didn't change any of my slicer or printer settings in between. I also tested several different types of filament from different companies.
Napsal : 02/06/2021 8:55 pm
RE: Underextrusion issues immediately after firmware update
Posted by: @turtlelore2
If you develop under extrusion after an update, consider downgrading to see if the update is the problem.
Napsal : 03/06/2021 10:10 am
ssill2
(@ssill2)
I have the 3.10 firmware on two MK3S+ printers and I've not seen any changes in extrusion.   What filament type?
Napsal : 03/06/2021 12:34 pm
