Unable to print with a .40 nozzle on my MK3
BigEd358
(@biged358)
Good Morning.  For some reason I'm unable to print on my MK3 with a .40 nozzle.  No matter what I try the filament doesn't extrude out of the .40 nozzle correctly (studders, prints thin or not at all)  and I have to abort the job.  I have the latest Firmware, updated the nozzle setting on the printer  as well as in the gcode, but the same problem.  I'm guessing it's some setting in Slicer?    Note, when I print with the .60 nozzle and settings it prints perfectly!  I don't get it.
Any assistance would be greatly appreciated!  Thanks!
Opublikowany : 26/01/2021 4:17 pm
RE: Unable to print with a .40 nozzle on my MK3
Have you been able to try a second 0.4mm nozzle?
Opublikowany : 26/01/2021 9:12 pm
Posted by: @biged358
Also, check your slicer settings again.
Opublikowany : 27/01/2021 1:13 am
I would try a second nozzle first, then use the stock slicing profiles.
Opublikowany : 27/01/2021 12:26 pm
