Two completely different profiles, same part?
LBussy
(@lbussy)
Cunning Linguist
I just got some TPU (man did I ever get a jam the first time I loaded!!) and I am doing some experimentation.  Thanks to a kind soul in the Discord channel, I have a pretty good profile from which to work with the TPU.  My challenge comes however with a specific application.
I am making a coaster where I want the first couple of layers to be TPU (think a rubber mat against the table) and then PETG after that.  I can sort of muck my way through changing a lot of the settings with first layer settings and height layer settings, but I'd really like to use all of my optimized PETG settings when I start printing that.
The best idea I can come up with is somehow print two coasters - one from 0.0 to 0.50 for instance with the TPU settings, and another one that only starts at 0.50 and finishes with my PETG settings.
Hopefully, that makes sense?
Bad decisions make good stories
Opublikowany : 22/03/2020 12:49 pm
vintagepc
(@vintagepc)
RE: Two completely different profiles, same part?
Have a look at this:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../simple-way-to-print-in-real-multi-color-without-mmu-or-layer-height-based-changes/
I used it successfully for simple parts with only a small number of changes before I got an MMU.
Opublikowany : 22/03/2020 1:40 pm
LBussy
(@lbussy)
Cunning Linguist
Hm ... maybe?  I need to play with that.  In my head, I make a copy of my part, import both, and use the "Part Manipulation" to use a different virtual head for the base?
Opublikowany : 22/03/2020 2:34 pm
