Trouble printing Prusa Printer Enclosure V2
unregistered
(@unregistered)
Print project: https://www.prusaprinters.org/prints/3673-mmu2s-enclosure
Filament: Prusa PETG Jet Black 1.75mm
Printer: Prusa i3 MK3S
Surface: Smooth PEI sheet cleaned with 70% isopropyl alcohol and windex
I downloaded the gcode directly and immediately went to print it on the my prusa i3 MK3S. What went wrong? Is part 1 due to insufficient bed adhesion?
Trouble with part:
prusa_mmu_enclosure_1_02mm_pet_mk3s_15h36m.gcode
prusa_mmu_enclosure_7_02mm_pet_mk3s_20h40m.gcode
This topic was modified před 7 years by unregistered
Napsal : 13/10/2019 5:34 am
unregistered
(@unregistered)
RE: Trouble printing Prusa Printer Enclosure V2
Also for prusa_mmu_enclosure_6_02mm_pet_mk3s_21h2m.gcode
Some of the bottom parts seem to have a low quality print whereby the filament can be cut out easily, is there any way to prevent this?
Here is a similar result from another part:
Napsal : 13/10/2019 5:44 am
rmm200
(@rmm200)
Post a picture of a Z axis calibration square. like from Live Adjust.
Guessing your Z is high.
I sliced all my own parts for the enclosure. If you do that, you can add brims where needed. Not that those parts need brims.
I also do not use 70% IPA. I prefer 99 but will use down to 91.
Bridges - especially without supports - will always have surface problems. The filament has nothing to bind to.
Napsal : 13/10/2019 6:19 pm
unregistered
(@unregistered)
Posted by: @robert-rmm200
Hmm, strange, I printed all my prusa replacement parts just fine, maybe they were small and used up only around the center of the bed, I will try to get a z calibration square later.
As for the surface problems, would it be better if I added supports in the slic3r?
Sorry, I'm new to all these
Napsal : 13/10/2019 10:02 pm
rmm200
(@rmm200)
It is a judgement call. For interior surfaces that are not visible - don't worry about it.
You can always try supports, but they cause their own surface defects.
Napsal : 13/10/2019 10:08 pm
1 lidem se líbí
unregistered
(@unregistered)
I lowered my live adjust z and printed the prusa_mmu_enclosure_7_02mm_pet_mk3s_20h40m.gcode fine. Had not tried it on the other parts that failed previously yet. I emailed prusa staff and they said the bed might not be leveled which I suspect as well(The first time setup went fine however, I have since shifted the printer to another location). If the bed isn't leveled, would that affect my lack enclosure in anyway? I don't have to print it again, do I? ;(
Napsal : 15/10/2019 11:00 am
rmm200
(@rmm200)
Lack enclosure is just a box. It would not matter even if the angles were visibly off.
Use it and be happy. Love mine - keeps dust off and noise down. I do print with a door open.
There are some nice accessories for it. I use the door handles with magnet inserts.
Napsal : 15/10/2019 4:38 pm
unregistered
(@unregistered)
Alright, so what causes PETG blobbing to occur? Any way to prevent it?
BTW. is it common to waste lots of filament on failed prints when first starting out? I seem to have wasted quite an amount already.
Napsal : 16/10/2019 10:27 pm
unregistered
(@unregistered)
Oh and here is the test print
Napsal : 16/10/2019 10:31 pm
