[Solved] Triangle artifact in printing an extruded ellipse
RB
 RB
(@rb-2)
Hi everybody,
why is my MK3S printer putting this kind of triangle shape into my elliptic bowl.
Everything else looks perfect but on one side of the curved wall it starts making this triangle shape, which is also visible in the inside of the wall.
Printer: MK3S with MMU
CAD: FreeCAD
Slicer: latest PrusaSlicer
Thanks for any help.
Regards
  René
Best Answer by jwvaughn:
With FreeCAD  Create Mesh from shape, I would suggest reducing Angular deviation - I think the default is 15 degrees and I usually run it at 5 if I have curves in the model. You will get smoother curves. You can also try reducing the Surface deviation - I run at 0.2 but I don't know what the default is.
The disadvantage in reducing the angular deviation is that the file size will increase as more triangles are used for the approximations.  If I'm doing something with no curves I tend towards 15 degrees to reduce file size.
jwv
Posted : 02/02/2022 1:14 pm
RB
 RB
(@rb-2)
RE: Triangle artifact in printing an extruded ellipse
Here is also the 3mf file Ellipse_Bowl from the PrusaSlicer 2.4.0.
Posted : 02/02/2022 2:09 pm
sylviatrilling
(@sylviatrilling)
That triangle is in your .stl
Mk3S+,SL1S
Posted : 02/02/2022 2:46 pm
Amoda
(@amoda)
If you made the file in blender (or if someone else did) the smoothing visualization ('shade smooth') does not directly effect the mesh (triangles). This is a particularly common issue with cylinders. There is a method for smoothing the mesh appropriately, but I do not recall it offhand. Google searching smoothing mesh cylinders yields a fair amount of methods though if you want to try your hand at it. This may be an option to smooth the model without loosing your edges. https://blender.stackexchange.com/questions/167867/smoothing-cylinder
Posted : 02/02/2022 3:08 pm
RB
 RB
(@rb-2)
Thanks a lot I didn't realize the error in the stl-file. I made the stl via FreeCAD and after doing a manual "Tesselate shape" in FreeCAD I could see the error there too. I guess I have to find this "smooth mesh" method in FreeCAD.
Again thank you very very much for the fast help.
Posted : 02/02/2022 3:46 pm
jwvaughn
(@jwvaughn-2)
jwv
Posted : 03/02/2022 7:24 am
jsw liked
RB
 RB
(@rb-2)
thanks for the info I tried it but it didn't work the same triangle artifact was rendered. But your hint let me check the other "Meshing options" and the "Netgen" with "Optimize surface" and "Very fine" Fineness made the artifact disappear.
Thank you very much.
Regards
  René
Posted : 03/02/2022 7:14 pm
jwvaughn
(@jwvaughn-2)
👍 Glad to hear you found a solution.
I should have asked what version of FreeCAD you were using.  The selections for doing the mesh changed at some point.  I'm on version 0.19 and Standard is working well for me (I think v0.18 were where the mesh options changed).  On the older versions I sometimes had to play with different methods and settings to generate the correct mesh.
Posted : 05/02/2022 3:59 am
RB
 RB
(@rb-2)
I'm currently using FreeCAD 0.19.2 and the result with the previously mentioned settings looks great.
Thanks again for the fast help.
Posted : 09/02/2022 7:51 pm
