TPE won't stick to Printbed...
Página 2 / 2
christian.ho
(@christian-ho)
RE: TPE won't stick to Printbed...
Print Settings TPE 90A
Here are the settings I used. Please check them, compare to the default, and decide for each whether to use it or not.
I think the huge brim was the most important change.
Respondido : 23/02/2021 5:50 pm
Marcos
(@marcos)
Thanks Christian! I was finally able to get a good print out of this filament with your params. Printing in the PEI sheet it sticks quite nicely, the only issue I can find is the massive brim being part of the piece. I'll tinker with the config a bit, if I find a way around the brim I'll post it here.
Respondido : 24/02/2021 10:57 am
DinoPrint
(@dinoprint)
TPE params
Hi Christian
Could you please reshare the params for this filament - for some reason they are stripped from your original post - having exactly the same issues.Tried Magigoo Flex but it really did not do a lot of good.
Thx
Respondido : 29/09/2021 9:30 am
christian.ho
(@christian-ho)
Settings
Hi PetHar,
Sorry for my late reply. I hope it is still helpful.
In my memory, the most important setting was a huge brim (e.g. 20mm) and I am not sure right now if that is included in the settings that I uploaded.
Respondido : 25/10/2021 8:11 pm
Página 2 / 2
