This print is driving me nuts
Efezeta
(@efezeta)
I'm trying to print a piece which is an "arc". This is the side view:
Side view
I had a somehow successful print with an orange PETG but never again after many prints. I tried the silver PLA and always ends up on a part looking like over-extruded. I tried many combinations. This is when it gets messed up:
Problem
I even get "crash detections" mid-print. This is the slice around that time from Prusa Slicer:
I'm not sure what I'm doing wrong nor what else to debug. Thanks!
Printer: Prusa i3 MK3S+
Layer Height: 0.3mm
Nozzle: 0.4 mm brass
Filament Setting: "Prusa PLA" from the template
This topic was modified před 5 years 2 times by Efezeta
Napsal : 11/09/2021 4:36 am
Save project from the File menu (Save as) as an 3mf file. Zip it (IMPORTANT!), then upload here. That gives up STL *and* all your settings.
Napsal : 11/09/2021 8:18 pm
Efezeta
(@efezeta)
Attaching 3mf
this.3mf
Attached, thanks!
Napsal : 12/09/2021 4:44 am
Dan Rogers
(@dan-rogers)
Eeeep
All I can say is - that was not designed for FDM printing - but with enough supports .... EEEEP
Napsal : 12/09/2021 6:24 am
Swiss_Cheese
(@swiss_cheese)
Have you tried it like This ?
@efezeta
This_Swiss.Zip
Let us know how it goes,
Swiss_Cheese
The Filament Whisperer
Napsal : 12/09/2021 5:31 pm
Xanthe
(@xanthe)
Nozzle diameter / layer height ratio
Bridging and/or overhangs are usually best printed with a layer height not exceeding 50% of the nozzle diameter.
Napsal : 13/09/2021 10:03 pm
Dan Rogers
(@dan-rogers)
Get an injection molder
Seriously - that is not a good FDM design.
Napsal : 16/09/2021 11:12 am
towlerg
(@towlerg)
separate
Print in the orientation swiss posted and make the feature that sticks out separate. Screw, clip on, glue whatever, it'll probably be much stronger and it will certainly look better
Napsal : 16/09/2021 2:08 pm
