This PLA block my prusa
3Dfiguras
(@3dfiguras)
Good night
Recently I have bought a prusa mk3s+ to print. The prints with PLA and PTEG is so good but this monday i have bought this item
https://www.impresoras3d.com/producto/pla-impresoras3d-com-azul-oscuro-seda-1-75-mm/
how it is specify in web, the configuration to this filament it is a as normal pla, but it is not true, I have tried to print with the same configuration of mi normal PLA and the extrudes do noise, (lost steps), the filament no drain correctly and finally the nozzle has been blocked.I have change the speed to do it more slow but it not work . i do not know how i can print it.
The box specify as material silky .
Please can someone give me a solution?
thanks in advance
Opublikowany : 15/02/2022 10:13 pm
RE: This PLA block my prusa
With silk, I usually print 10 degrees or so hotter than regular PLA. You may want to run a temperature tower such as this one: https://www.prusaprinters.org/prints/39810. Important to use one with higher temperature on the bottom, so you don't gunk up your nozzle right away.
Opublikowany : 16/02/2022 12:53 pm
