[Gelöst] Thin walls missing after sliceing
Redy
 Redy
(@redy)
Hello Makers,
I have relatively small object that i need to print. I have 0.25 nozzle but it seems that i still need smaller one.
Whenever i tried to slice the object at my needed size the walls just disappear. Unfortunately size cannot be change d as it is for car model.
Only solution that comes to my mind is to somehow cut it in parts and then glue it together, which is something i don't really want to do.
Please have a look on the model if someone has an idea 🙂 I am newbie so help is needed! 🙂 Thanks
STL: https://drive.google.com/open?id=1bTbmd1U_WmaqxQbpyjmnyuEP-TuAVutZ
BR,
Radek
Best Answer by jwvaughn:
I tried to download the file but was required to logon to Google.  I logged on and tried again and did not have permission to download.  If Google Drive is like Drop Box, you set it up so the the link can be opened and downloaded by anyone.
My guess is that you don't have thin wall detection turned on in the slicer.
Veröffentlicht : 03/07/2019 3:08 pm
jwvaughn
(@jwvaughn)
RE: Thin walls missing after sliceing
Veröffentlicht : 03/07/2019 7:54 pm
Redy
 Redy
(@redy)
Thank you. Found the thin walls in settings and its fixed!
Diese r Beitrag wurde geändert Vor 7 years von Redy
Veröffentlicht : 03/07/2019 7:59 pm
