Taulman nylon 910
pingu
(@pingu)
Taulman nylon 910
Any advice on how to print this?
I managed bed adheison. I gluesticked it, and then made an even thin coating of this with a wet towel. So adheison is finaly good. Bluetape dis not work for me.
Print bed was at 65 degrees and nozzle ad 255 degrees celsius. I do not have an enclosure, i tried to cover the peinter with blankets and slighly heat it with a heatgun, but i only managed to heat this up until 32 celsius. I will try a cardboard enclosure soon, but not shure if this is my only problem.. any advice would be great. As you can see in my pictures, the printing quality is very worse.
I put the new sealed roll right into my newly printed drybox. Should i dry the filament even if its new? Is this the issue? I have very worse print quality and very worse l ayer adheission
Publié : 06/02/2020 7:11 am
natehansen66
(@natehansen66)
RE: Taulman nylon 910
I haven't used the 910 yet but the roll of 645 I had needed to be dried right out of the bag.
Publié : 06/02/2020 9:33 pm
KTR
 KTR
(@ktrpb)
You need an enclosure for 910. It's absolutely required. I keep the bed at 100C, glue on glass (but glue on PEI sheet should work too).
You can dry the filament spool inside the enclosure.
Publié : 13/02/2020 8:00 pm
