T Rex 38 Hours Failed Print
Matthias
(@matthias)
Alôha
I Wanted to print out a T-Rex Head on a little Platform A Thingiverse Part.
It went pretty good but the last tooth's were printer out with not enough material, even tho there is over the half left in the spool..
Also there were 2 layers missing before and also at the top.
I sliced it with S3D with the settings the have for the MK3 Printer and changed nothing but the temperature for the nozzle.
I don't know if the error is coming from the Slicer, from the Printer or from the Model itself.
The Model is a quite popular one on Thingiverse and got printed out a lot of time.
The slicer looked really good, i watched every layer back and i could not see any errors.
So there would be only the printer left.
I ordered the MK3 already assembled and printed out 4 Parts that where at the SD card that i received with the printer.
This 4 Prints The Castle, the Nefertiti, the Triceratops Head and the Adalinda got good-very good.
The only difference to the model now is that i scaled the T-Rex to 135% 138% would be the max scale.
So it is higher than the others and that makes me thinking that the printer gets some troubles in a higher Z, because of the less material and the missing layers
I hope that someone can help me with this and knows the Error
The pictures are attached below of the Model.
Best regards M.
Opublikowany : 01/06/2018 5:28 pm
Aravon
(@aravon)
Re: T Rex 38 Hours Failed Print
Looks like a partial nozzle clog to me
Opublikowany : 02/06/2018 6:44 am
Zach
 Zach
(@zach-3)
I tend to agree. I wonder if the OP has had any success printing since this?
Opublikowany : 04/06/2018 4:55 pm
