surface finish of circle sometimes interrupted with line or cut
blatti
(@blatti)
Hi there,
how do I overcome this issue? I design something which is round - I can already see at the slicer that there will be an interruption of printing. And eventually it looks like the slicer is telling me - how to improve? Changing the stl file to more detailed triangles did not work.
Thanks a lot
regards Stefan
if you can imagine it - if you can design it - you should print it!
Make the impossible - possible!
Napsal : 13/09/2020 7:36 pm
RE: surface finish of circle sometimes interrupted with line or cut
That’s the seam. It’s unavoidable, the slicer on default settings will usually try to place/hide the seam in corners. Unfortunately circles don’t have corners to hide them in.
You can minimise them by tuning your settings but you can not get rid of them with fdm printing.
Napsal : 13/09/2020 7:51 pm
blatti
(@blatti)
thanks a lot - than I have to accept it - but the seam is not always on the round surface - it is only at the end regardless if I print it on the upside down. And regardless if I print different layer higth – it does have the same length. 6 mm on 0,25 or 0,35.
Napsal : 13/09/2020 8:26 pm
It is always there but it’s gets moved around, however where it gets moved depends on the previous layer, when you have other geometry like I can see in your pics then that influences it’s position. That’s why they are more grouped at the top. If you look you can see them further down too.
Sometimes it’s better to use aligned or rear so they all go in a single line which can make them easier to post process if required.
Napsal : 13/09/2020 8:33 pm
blatti
(@blatti)
- in my case I did put some engraving into the cylinder - fixed. Thanks neophyl
Napsal : 14/09/2020 6:50 pm
jsw
 jsw
(@jsw)
You can set the location of the seam in most slicers.  I frequently use the 'rear' option to have it show in a location not normally visible in most of the round things I print.
Cura has a 'hidden' option, which subdues the seam somewhat, but not totally, by kind of wiping it toward the internal part.
Napsal : 14/09/2020 7:21 pm
blatti
(@blatti)
thanks jsw
Napsal : 19/09/2020 9:54 am
