Support Separation Distance Top/Bottom
I've found in playing with support separations that if I set the gap tight enough to get the tops ok, I get the bottom of the supports sticking to the (inner) top surfaces of the model.
Can I set the separation of the bottom different from the top in Slic3R?
In general I'm looking on advice for easy to remove supports with a 0.6mm nozzle, pla, and internal cavities which are hard to access.
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
Respondido : 10/08/2018 8:59 pm
Re: Support Separation Distance Top/Bottom
I am not aware of such a capability using Slic3rPE. This is one area where Cura has an advantage with separate top and bottom support Z distance configuration options.
Respondido : 10/08/2018 9:13 pm
