Support & Finish Issues
I recently purchased a Mk3S+ and have been doing battle with the slicer, ( been using Cura for years ) particularly with the support. Another forum member directed me to the thread about support and I saw bobstro's post. ( Link for entire thread.. and it's a good read
https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-hard-to-remove-supports/ )
I chose the elephant file on Prusa's site because of the tusks overhang and despite numerous attempts following bob's suggestions I wasn't able to get a successful print. Not one to give up I tried and failed many times until I discovered my heat setting for the PLA was set at 215. I turned it down to 200 and ended up with a print I could actually remove the support from. Thanks for that bobstro.
I do have two questions if I may...
1 - Even though I could remove the support it wasn't as easy as I'd like. How do I make the support " thinner " so it detaches easier?
2 - The finish didn't turn out as sooth as others I've seen and I don't know why. A screenshot of the gcode breakdown is attached.
TIA
RE: Support & Finish Issues
I couldn't attach the second pic without it overlapping the text so here it is.
