suddenly bad surface
Matt
 Matt
(@matt-33)
got my printer end of last year and had quite some nice prints.
However the quality started too look bad, especially the walls, like in the below print.
Thought of an over extrusion issue and printed an calibration Object and measured the wall thickness, which was a bit off.
so i changed the extrusion multiplier from 1 to 0.98 and got a wall thickness of around 0.42 to 0.45 with a setting of 0.45 in slic3r PE.
but still the same. also reduced the temp about 10C and checked belt tention (x/y about 270)
same issue with different filaments an manufactures, all PLA
any Suggestion what i should check next?
Veröffentlicht : 17/01/2019 4:58 pm
Jerry
(@jerry)
Is it speed sensitive?
Veröffentlicht : 17/01/2019 7:32 pm
ivan.c11
(@ivan-c11)
Re: suddenly bad surface
Did you figure it out?
Veröffentlicht : 24/01/2019 10:32 pm
