strange diagonal artifact in print
Chris Young
(@chris-young-2)
Hi everyone,
Please have a look at this print .
https://1drv.ms/u/s!ApEIZVkQ_KsXq3SzM5O8hkaoBeKA
Notice the diagonal artifact? I believe this is the origin of each print layer (seam) but I'm not sure why such an artifact is showing up? Thoughts? I'm using...
mk3 running 3.2-555 firmware
slic3r 1.39.2
PETG filament
thanks for your help
Cheers
Chris
Postato : 18/05/2018 10:41 pm
Rosparovac
(@rosparovac)
Re: strange diagonal artifact in print
I think this is seam too.
Try to change seam setings in slicer, if you have nearest (default) this happen all the time. Try random of rear and make sure the "external perimethers first" is switch off.
GL
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
Postato : 19/05/2018 9:25 am
Chris Young
(@chris-young-2)
GL
Thanks for the reply....Yes it is the seam. I printed some practice pieces using all the options. Aligned or rear seem the best as the seem shows the least. Random creates little speckles throughout the entire surface and looks like a lower quality print.
Cheers
Chris
Postato : 19/05/2018 6:45 pm
