Strange behavior samples print perfect same file sliced not
R3DGeek
(@r3dgeek)
Hi i'm baffelt When printing from the original SD and I used the Batman one as test file. The print is perfect so first layer looks perfect and all the rest as well. When I slice it with prusaslicer with the original profiles I have gaps between the perimeter and the rest. But also between the inner lines. The after that print from the SD the test file It works perfect.
So I know the filament is not the problem. It has to be the prusaslicer. How does it come?
Is it in Print settings, Filament or Printer settings?
I have a Prusa I3 MK3S
Anyone experience with it?
Publié : 22/12/2019 1:23 pm
RE: Strange behavior samples print perfect same file sliced not
Sounds like your extrusion multiplier in your filament settings might need to be bumped up a bit. Your pre-generated gcode looks good, so your Live-Z must be OK. It would be most helpful if you could post a picture (drag & drop into the edit box) sh0wing side-by-side comparison of your 1st layer results.
Publié : 22/12/2019 9:21 pm
R3DGeek
(@r3dgeek)
@bobstro
I'll do this tonight.
The thing is I was playing with that but you would say that the original profiles would be perfect.
Publié : 23/12/2019 7:58 am
