Stains on my prints
I recently start printing ABS using the smooth pei steel sheet. Prusa recommends to use glue so it don't damage the smooth sheet when removing the part. Te problem is the glue are leaving stain in the parts from previous prints. Any suggestion how to avoid this or maybe another type of printing surface?
Thanks for the help
Opublikowany : 28/04/2022 3:21 pm
RE: Stains on my prints
Does a water + soap wash remove the marks? If not, you may have to apply a fresh coat of glue each print.
Opublikowany : 03/05/2022 8:53 am
