Staggering in Y axis of print
Rekyua
(@rekyua)
I have a Prusa i3 MK3S I put together from the kit. It's not quite layer shifting.
Belt tension is at 263. Is it from the carriage? It does move slightly but its from the U bolts on the bearings. I tightened them per the instructions (as soon as the nut reached the surface of the carriage) but am I suppose to tighten them tighter so theres no movement? Or is it something else?
Napsal : 25/08/2020 7:10 pm
Rekyua
(@rekyua)
RE: Staggering in Y axis of print
Found the issue, posting for anyone else that gets it.
The u-bolts are suppose to be past the wiggle point for the bearings so if you just do surface tighten like the instructions say you're not done. I emailed Prusa to check on that. I still had the staggering but I actually got a clear case of shelving after I tightened the ubolts and I found the motor pulley of the y axis was just slightly loose. After I tightened it my prints are back to being smooth.
Napsal : 30/08/2020 1:56 pm
jsw
 jsw
(@jsw)
IIRC, TFM said to tighten something like 90 degrees past the wiggle point.
Napsal : 30/08/2020 5:37 pm
Rekyua
(@rekyua)
@jsw
No it doesny, TFM states the following.
My issues fixed already.
Napsal : 30/08/2020 7:53 pm
