Spiral marking on cylinder print
LT
 LT
(@lt-3)
I'm printing a tube and the surface is getting all these spiraled print errors.
My prusa slicer file with the stl is here: https://drive.google.com/file/d/1ejtldJZrYMR7lc12VTuXMHx3ugXRk7Vz/view?usp=sharing
I appreciate all feedback on what is causing this and how I can resolve it for a smooth finish.
Napsal : 16/02/2021 12:25 am
Dan Rogers
(@dan-rogers)
RE: Spiral marking on cylinder print
I love that raw clay circle effect - how did you do it?
Napsal : 16/02/2021 3:08 am
LT
 LT
(@lt-3)
@dan-rogers I don't know how or why this is happening ... but it's not the look I'm going for and would appreciate some help to make it go away 🤡
Napsal : 16/02/2021 10:42 pm
Dan Rogers
(@dan-rogers)
Could you share the STL or 3mF file, and some information about how you set this print up?  It does look to be possibly an under-extruding problem - so what filament, what nozzle temps.  How well is your extruder working?  Do you hear clicking sounds?  Are you printing in an enclosure?
Napsal : 17/02/2021 3:50 pm
LT
 LT
(@lt-3)
Fixed. The issue was idler screw tension was loose (not calibrated correctly).
https://help.prusa3d.com/en/article/idler-screw-tension_177367
Napsal : 18/02/2021 6:02 am
Dan Rogers
(@dan-rogers)
That would cause under extrusion for sure.
Napsal : 18/02/2021 4:29 pm
