Spine Print from Thingiverse
hhughes
(@hhughes)
Hey, I apologize in advance - I'm a super noob right now.  I have gotten the sample Prusa supplied models to print pretty well, but I now want to try printing something I found online.
https://www.thingiverse.com/thing:697686
So, I downloaded it then:
1) imported the STL into Prusaslicer
2) Scaled it down to fit the plate
3) Did Slice Now
4) Exported the g-code
My prints aren't sticking at all.  The model looks like it has very very little contact with the plate.  Does anyone have any ideas?  I saw an option for "Supports" but I'm not sure if that's something I should try?  Can any of you guys help?
Thanks!!
Veröffentlicht : 22/07/2019 10:47 pm
Peter L
(@peter-l)
RE: Spine Print from Thingiverse
Yeah, you're going to need supports for this to print properly.
Veröffentlicht : 24/07/2019 3:10 pm
This image in the file set explains it all: enable Support on build plate only.
Veröffentlicht : 24/07/2019 3:46 pm
hhughes
(@hhughes)
Hey thanks - I'm really new.   I have played a bit with supports, and that's definitely a huge thing that helps.
Is there any modifications to the supports settings that you guys recommend?   Some of my supports are a bit too attached and hard to break off.  Is there an optimal modification that you guys suggest?
Veröffentlicht : 24/07/2019 4:20 pm
Posted by: hhughes
It's trial and error depending on the part. Some parts need close supports,other parts can live with a larger spacing.  I almost always use the defaults because the time it takes to tune a single one-off part isn't worth the effort.
One trick though is to slow print speeds down to a minimum... let the plastic cool as much as possible between layers. But setting the interface contact distance to 0.2 mm might help on something like the spine.
Veröffentlicht : 24/07/2019 4:44 pm
Oh - one other place I do use to make changes, again very part specific, is the angle - Overhang Threshold - changing it to 0 allows the slicer to decide whats best, and sometimes setting the angle to low values like 10 degrees can help ... again, something to play with and 100% depends on what the part looks like.
Veröffentlicht : 24/07/2019 4:57 pm
hhughes
(@hhughes)
I'll try the slowing things down setting.
Is there a good "how to use PrusaSlicer" manual?  I am having real trouble finding something up-to-date.   For example - I'll attach a picture.  It's of one .STL file model.  Is there any way in PruseSlicer  to remove the red circled part?  Or at least tell PruseSlicer to not print that area?
Thanks so much - I really appreciate all the help and advice.
Veröffentlicht : 24/07/2019 5:01 pm
That slice position will fail -- don't bother trying.  You need to lay the spine down as shown in the Thingiverse examples.
Search Slic3r.org and there's a manual that can help some - Prusa is copying Slic3r and making additions. Someday there is a plan to have a Plicer manual, but no time frame at present.
But to separate a part into it's shells, there are buttons across the top that split the part into parts or objects (if they are shells to begin with).
Veröffentlicht : 24/07/2019 8:55 pm
Easiest looks like this" scaled 35%
Or if you really want it to print vertical, 50% cut in half and lower part flipped:
Veröffentlicht : 24/07/2019 9:09 pm
So you're saying we need a brace for this back?
Veröffentlicht : 24/07/2019 9:18 pm
RAH1
 RAH1
(@rah1)
Posted by: bobstro
No.  I think he is saying he doesn't want it back.  Either that or he needs a Chiropractor to fix his back.
But that was some time back.
LOL
RAH
I am the inveterate tinkerer. I can tink up most anything.
Veröffentlicht : 25/07/2019 12:33 am
