Sphere Lampshade Print (top fails)
Dr. Mabuse
(@dr-mabuse)
i did buy a copy of a sphere lampshade and did some test-prints of the bottom and the top of the lamp before i start an 18h print.
I can print the bottom without probs in (esun) PETG and (esun) ABS+ but the top part always fails. This is the lamp shade
https://cults3d.com/en/3d-model/home/sphere-lampshade-3dprintlover
I cant publish the whole file here so here is the top part i try to print:
 Would you people consider this basicly as printable? If yes, can i do it with a 0.6 nozzle or do i  need to downgrade to a smaller nozzle? What would be the best approach to find out the correct parameters? I think i need to change print parameters for exactly this end part. The rest should print fine.
Publié : 19/07/2021 6:14 am
Dan Rogers
(@dan-rogers)
Zip it then upload the sliced .3mf file
If you have sliced the part you want us to look at, save that project in prusa slicer (captures your setting).  then zip the resulting .3mf file and then you can upload the zip file with your post here.
Publié : 19/07/2021 6:37 am
