some sort of extruder issue
Luke Rickert
(@luke-rickert)
Hi everyone I have done a good deal of printing over the years but have not seen this issue before. This MK3s has a good number of hours on it but generally works with one issue. It builds up a blob that then attaches to a print and causes a crash. We are printing a bed full of these parts and within the first few layers you can see what happened.
I have noticed that the extruder loosens up over time but I have retightened it without change in the issue. The machine is newly calibrated, the rough print bed is clean (washed in soap and water and not touched). I didn't slice the part but I guess they are using the default settings for Prusa PETG, .4 nozzle and .2mm layers.   The nozzle could be getting over size but only printing petg and pla I think the wear rate should be rather slow.
thanks
Luke
Opublikowany : 27/09/2022 6:43 am
RE: some sort of extruder issue
Check above your heat block at the gap between the heatsink and heat block (Heatbrake) for leaking filament.
Opublikowany : 28/09/2022 10:24 am
