Solid bottom layers only on bottom
sebastian.n3
(@sebastian-n3)
how do I configure Slic3er to print bottom layers only on bottom layer?
Thanks for any ideas...
Those "flying bottom layer" in the middle should not exist, nor it can be printed...
Postato : 13/12/2018 11:07 am
alejo.v2
(@alejo-v2)
Re: Solid bottom layers only on bottom
Try setting the "top layers" value to 0. I think it may work.
Postato : 13/12/2018 6:12 pm
There is an infill setting for connecting layers and solid infill every X layers... did you modify the defaults?
Postato : 13/12/2018 6:22 pm
Knickohr
(@knickohr)
Utenti Moderator
Is your "thing" only 1 shell or more ?
Are the shells connected ?
Please check also for errors :
Thomas
Postato : 18/12/2018 12:34 pm
