small features turning into blobs - PETG printing
Tim G
(@tim-g)
I'm having trouble getting things to print that have small features alone on a vertical section.  For example, the nut holder on the fan shroud - the last several layers or just the nut holder and while the rest of the print looks fine, this section looks like it melted into a bit of a blob.
I also had similar issues with a rabbit model with thin ears sticking up by themselves.
Is there a setting I need to change?  I've already reduced the temperature to 225C and the rest of the print looks fine, not stringing etc.
Napsal : 18/12/2020 8:01 pm
Area51
(@area51)
RE: small features turning into blobs - PETG printing
I think you need more part cooling on the tiny parts.
Cooling settings is under filament tab - to do more advanced settings as fan speed, you need to be in expert mode.
Try changing the settings under Cooling Thresholds.
Napsal : 19/12/2020 4:26 am
