RE: Slicing model shows empty layers
The walls of the model are thinner than the printer can create so it won't try in those areas, try going into Print Settings -> Layers and Perimeters and enable Detect Thin Walls. If that doesn't work scale the model up a little bit, it might thicken the walls enough to print them.
Cheers
-Bob
Opublikowany : 23/02/2022 2:11 am
1 ludzie polubili
