Slicer Settings for Hardened steel nozzle E3D V6
Lvet
 Lvet
(@lvet)
Hello,
I am going to start experimenting with the Hardened steel nozzle E3D V6.
Except raising the temperature by 5C, are there any other slicer parameters that I should modify in the PrusaSlicer?
I assume that the Hardened steel nozzle that is sold on the prusa shop has a diameter of 0.4mm is that correct?
Cheers
Luca
Publié : 11/10/2020 9:10 am
Membre
RE: Slicer Settings for Hardened steel nozzle E3D V6
I have not had to alter mine to use these nozzles.
Publié : 11/10/2020 12:42 pm
manicminergb
(@manicminergb)
i had my nozzle replaced by prusa for a hardened one during a repair at my request, and had no end of problems, prints failing mid print etc. I did temperature towers for all my filaments, best was an increase by 10deg.C for nozzle temp.  but still had probs- tried  reduced flow rate etc. Finally gave up and replaced back to brass. have had no more probs.
I did notice on prints 4hrs and above, the nozzle temp dropped by 10 before going back to set temperature occasionally and suspected the  fan cooling effecting hard nozzle temp(steel has a higher temp coefficient than brass so loses heat quicker. The brass nozzles are cheap enough so there is no way i'me changing from them
Publié : 13/10/2020 6:10 pm
