Slic3r Settings
Craig
(@craig-4)
Slic3r Settings
Having a problem with my prints, recently installed a 1mm nozzle, and for the most part it seems to print ok.
slic3r seems to be putting this gap between the start and end of a loop.
it is made very obvious when I set the seam position to 'rear'
what setting could i change to fix this?
Publié : 10/09/2018 2:11 am
RufusClupea
(@rufusclupea)
Re: Slic3r Settings
I think I'd try alternative settings to "rear". I'm not sure where "aligned" puts the seams, but if there's a way to align them on a corner (rather than the middle of a side) it might be easier/less noticeable to sand the nubs off in post-processing. YMMV.
That's "MISTER Old Fart" to you!
Publié : 11/09/2018 7:06 pm
Re: Slic3r Settings
Hi Craig,
Never used a nozzle that big!...
How about turning the model 45degrees so that there is a corner at the rear!?
Joan
Publié : 11/09/2018 7:11 pm
Re: Slic3r Settings
Try Nearest and it'll try to out the seam in corners. Z-seam handling is a weak spot in Slic3r. Cura has a lot of hiding options. KISSlicer has a lot of tuning options. You can never eliminate them, but you can hide them in corners.
Publié : 11/09/2018 9:52 pm
