Slic3r PE and PrusaControl both hang on exporting GCode.
roach374
(@roach374)
I'm trying to slice and export a model that I've printed many times before. For some reason, both slic3r and prusacontrol will slice it just fine, but then hang at around 95% when exporting to Gcode.
Anyone know how I can troubleshoot this? Are there logs somewhere I can look at? I'm running slic3r PE on a mac (Mojave), and this doesn't happen with all models, just some.
STL file is attached. (Rotate flat side down).
EDIT: Okay, I guess I lied. The forum won't allow me to attach the STL file. (After all, why would anyone want to attach an STL file to a post in a 3D Printing forum?)
Ce sujet a été modifié il y a 7 years 2 fois par roach374
Publié : 11/05/2019 2:20 am
RE: Slic3r PE and PrusaControl both hang on exporting GCode.
STL is NOT attached.  STL's need to be zipped, then attached.
Publié : 13/05/2019 3:44 pm
