Settings for decent supports? (why not like other software by default!)
Alpha
(@alpha)
One oddity I've always found (indeed others have by forum posts) is PrusaSlicer (and PrusaSlic3r before it) has terrible default settings for supports - ie they're much too solid and rarely come off without having to hack away.
Other software (eg Cura, S3d etc) this seems to work perfectly first time - I've no idea why other software produces decent supports first time on their Mk3 profiles when Prusa themselves can't, but hey!
Can someone advise best settings to get it working properly?
Opublikowany : 06/07/2019 7:10 am
RE: Settings for decent supports? (why not like other software by default!)
I increased the z gap to 0.25mm and have no problems with removal. I'm not doing detailed miniatures or anything like that though. For larger parts, the support do work well.
Opublikowany : 06/07/2019 3:14 pm
Alpha
(@alpha)
Thanks bobstro - and just to be clear as the names are different, do you mean Contact Z distance? (in which case yes, I've done that also and agree it's improved, I just don't know why it isn't like that as default as everyone seems to have to do this!)
Opublikowany : 06/07/2019 4:07 pm
