SD card isn't listing "3mf" or "stl" files, only "g-codes"
freezey
(@freezey)
When I attempt to print from SD I don't see the "3mf" and "stl" files I've added in the list.
The file is called "aaa_dave_sd_3mf.3mf" so the characters should all be valid.
Do I need to convert them to another format like "g-code" before I can print them?
Any help is appreciated, thanks.
Veröffentlicht : 13/01/2023 10:42 am
RE: SD card isn't listing "3mf" or "stl" files, only "g-codes"
it wont.  You cant print those file types.  You SLICE those using a slicer.  That generates gcode.  gcode is all the movement commands.  Its that that printers can print.
Looks like you need to learn the real basics.  Try starting at https://help.prusa3d.com/category/prusaslicer_204
Veröffentlicht : 13/01/2023 11:12 am
