“Scarring” in several different places
Justin I.
(@justin-i-2)
Hello-
I printed the print in place iris box ( https://www.thingiverse.com/thing:1817180) last night and overall it turned out really great. Only had to free up a couple of spots with an xacto.
I did notice several spots where the walls had scarring for lack of a better term. They seem like seams between the layers but they’re in a bunch of different locations. Is this expected with this type of print? Are there any tweaks I can do to try to minimize these marks?
Printed on MK3S with the silver PLA provided in the kit. .2 layer quality preset and 20% fill set to gyroid.
Thanks in advance.
Napsal : 26/02/2020 12:52 pm
RE: “Scarring” in several different places
Most of what I see are seams.  You can try aligning them, or forcing them to the rear.  Past that, making them invisible is problematic and requires a huge effort to tweak jerk, linearity correction, z-lift and retraction... among other adjustments that affect seam quality.
Napsal : 26/02/2020 7:18 pm
Justin I.
(@justin-i-2)
@tim-m30
Thank you. I’ll play around with the seam aligning options. I had to print another of the same gcode last night, it came out identical, so at least I know it’s consistent!
Napsal : 27/02/2020 12:31 pm
