Rotating infill pattern.
Revel
(@revel)
I am wanting a honeycomb pattern in my translucent 3d print.  The Prusa honeycomb infill is rotated and not straight. Is there a way to change this? If not are there any ideas out there on how to achieve what I want?   The only thing I can think of is.
1 - Hand Model the honeycomb as part of the art.  This would actually be possible in my specific case.
2 - Use simplify 3d with the Prusa setup.  Been a long time since I've done that.  That could possibly work.
I'm thinking rotating the model on the plate is not really a good idea in this case. I think being in straight orientation will come out nicer for the application.
Thanks
Postato : 19/03/2022 6:59 pm
sylviatrilling
(@sylviatrilling)
RE: Rotating infill pattern.
Print settings> Infill > Fill Angle. Changing from the default of 45 degrees to 30 degrees should do it. You will need to be in "Expert" mode.
Mk3S+,SL1S
Postato : 19/03/2022 7:15 pm
Revel
(@revel)
Pfffft How did I miss this. And didn't see anything coming up in my google searches.
Thanks!
I probably missed it cause its at the bottom and not the Infill section. But now that you point it out i see the Advance stuff is at the bottom.
Postato : 19/03/2022 8:10 pm
