Ripple on top of object
Badz
 Badz
(@badz)
Hi
I need to print a large flat object and it used to work great with the original grey filament coming with the printer but now I get ripples with some pla filament bought on Amazon. I tried the a prusament pla and I have similar effect ( not as bad).
Has anyone seen this. I retighen all the screws I could find to not avail
Thanks
Postato : 01/06/2021 9:27 pm
Dan Rogers
(@dan-rogers)
RE: Ripple on top of object
Need more info to be sure.  Sure looks like "wavy like water" though - first layer too low.  What was your first layer like?  And do consider zipping and posting your sliced file (extension = .3mf) so we can see what's what.  It could be infill showing through too few top layers as well.
Postato : 02/06/2021 5:11 am
Badz
 Badz
(@badz)
thanks for having a look.
Hum.. first layer, huh ? well, I might have forgotten to tell one small detail : it used to work much better on textured plate, the photo above comes from a print on a smooth plate.
Ok, I need to run a test on textured , I suppose ?
10 - Stabilizing_Plate
Questo post è stato modificato 5 years fa da Badz
Postato : 02/06/2021 7:25 pm
