Resume after Pause problem, layer X/Y shift.
rogerinhawaii
(@rogerinhawaii)
I had to Pause a print at one point. The print head moved up and out of the way, as expected.
When I Resumed the print the head went backto where it had left off and continued on with the print.
HOWEVER, it appears that it didn't "quite" go back to the precise X/Y location of where it had left off, and the effect was that there's a slight shift in the rest of the print. Actually, the slight shift most definitely affected the next several print layers, but may (it's hard to determine) have somehow recovered to get back to the correct X/Y coordinates.
See the attached photo.
Is this a known problem? Is there a known solution?
Postato : 22/01/2023 12:59 am
