Rectangle support peeling up
simon
(@simon-4)
Hi everyone, I'm having trouble laying the rectangle shape supports. They are peeling up a bit while laying the first layer of the supports down. I've tried putting the nozzle up to 225 centigrade, but helping a bit. Has anyone else had this problem. Thank you
Opublikowany : 04/06/2021 11:40 am
RE: Rectangle support peeling up
Without further information if you are using a mk3 then that's normally a sign your bed isn't clean or your first layer live z isn't set properly.
Also you haven't mentioned what print sheet you are using or what material you are printing with.
Opublikowany : 04/06/2021 11:44 am
2 ludzie polubili
Dan Rogers
(@dan-rogers)
Curlies mean live z too high.  Wavies mean live z too low
Opublikowany : 06/06/2021 7:26 am
1 ludzie polubili
simon
(@simon-4)
@dan-rogers
Thank you for your help.
Opublikowany : 06/06/2021 9:51 am
1 ludzie polubili
